By following several tutorial I have managed to create the ground floor of my house and was very happy with it.
Now I am on to design the first floor. Now that I have done that I foind out that I can no longer edit the ground floor.
If I click on the level0 tab I can't select anything. I can add to it but everything that was created before adding the second level is no longer accessible.
Am I missing something?
Can't update level 0 after adding Level1
This topic has been viewed 5060 times and has 5 replies
Re: Can't update level 0 after adding Level1
Can you please send the SH3D file so that I can have a look at it
Check that you didn't accidentally activate Lock base plan.
@hansmex : I have checked and it is not.
@santbose: I have sent you a private email with my file. Sorry for the size. I had not realised it could be so big until after I sent it
santbose, did you succeed to fix ppmt's issue?
If I get some time I will start from scratch to see if the same happens again.
