High priority Keys.p12 certificate error..
This topic has been viewed 4687 times and has 4 replies
santhosh.chellamani
Post by santhosh.chellamani »
hi,
i am getting error while trying to run ant 'applet' on my command line.
error related to the certificate generated.
command used to generate : keytool -genkey -keystore keys.keytool -alias SweetHome3D
and certificate generation i have renamed the file as keys.p12
kindly help.
Regards,
santhosh
santhosh.chellamani
Re: Keys.p12 certificate error..
this is the final error.
[signjar] jarsigner error: java.lang.RuntimeException: keystore load: DerInputStream.getLength(): lengthTag=109, too big.
BUILD FAILED
The command used to generate the keys.p12 file is incorrect. As explained in the README.TXT file, it should be:
 keytool -genkey -keystore keys.p12 -alias SweetHome3D -storetype pkcs12
santhosh.chellamani
Thank you so much for the support, i was successful in deploying SH3D on my server.
I am able to open the applet on my server, but i am not able to import libraries.
Can you please help me in guiding how to include libraries to my online version.
Thanks and Regards,
Santhosh C
