I see that Ubuntu now comes in a 64-bit version. I don't know how long it's been available but I just noticed it.
Anyway, since I have a 64-bit capable processor and 4 GB of installed RAM, would I be better running SH3D under Ubuntu (or some other distro, if they still call it that) rather than Windows?
SH3D on Linux/Ubuntu
This topic has been viewed 6053 times and has 3 replies
- HawkDawg
- Country: Georgia, USA
- Contact:
Hawk
- digitaltrails
- Member
- Country: Wellington, New Zealand, New Zealand
- Contact:
Re: SH3D on Linux/Ubuntu
If SH3D is already running OK why would you consider an OS switch? You may run into other issues under Linux.
Having said that, all the desktops in our home are 64 bit OpenSUSE 13.1. I'm using the Linux 64 bit SH3D with bundled-java. It works very well. The one small annoying issue with Java under Linux is that it will only output to paper sizes available on my local printers. I tried playing games with virtual printers, but I haven't worked out a convenient solution. This means I cannot produce large A3 PDF's from SH3D under Linux.
- HawkDawg
- Contact:
I wasn't thinking of switching OS's. I was considering setting up a dual boot.
Printing isn't an issue with me. My printer doesn't work and I can't afford to buy another one.
It's the fact that I'm running a 32-bit OS and I can run a 64-bit Linux, which should take a little better advantage of the 4 GB of physical memory I have installed.
I did buy Win 7 64-bit and a 32-bit disk, but I don't really care much for Win 7 so I gave the 64-bit disk to a friend.
I still have the 32-bit disk laying around somewhere, but for right now I'm sticking with XP.
I always did like Linux but I couldn't spend a lot of time in it because of the games I like to play.
Hawk
HawkDog, I have used Ubuntu 64x Linux for 4 years now and love the lack of non-sense from MicroSoft. SH3D does work on my Ubuntu 14.4 LTS. I just upgraded to the latest version and it works. I don't print, so not an issue for me. I sometimes take a picture, using GIMP.
