Hi
I am using sweethome 3d on an Arch Linux system. Every time I click on preferences the program shuts down instantly and I have to restart it.
Thanks
Crash on clicking preferences
This topic has been viewed 12966 times and has 19 replies
WhiteVanMan
- Country: Nenagh, Tipperary
Re: Crash on clicking preferences
Read the FAQ for solutions.
WhiteVanMan
Hi
Thanks for the reply. I found the relevant part in the FAQ after posting. It works if I download the webstart file but I would rather use the sweethome3d from the arch linux repositories, its tidier and looks after the updating. I cannot find the .sf file to amend with -Dcom.eteks.sweethome3d.j3d.checkOffScreenSupport=false arch must have a different method of organising its files. Do you know where it is, is it in a .jar file?
I don't know. I use Ubuntu in combination with the installed version, which I download from the website. Installation is no more than extracting the zipped file into a directory.
If you use the web star version, make sure you have Java 6 installed on your system. Other java versions cause problems.
WhiteVanMan
Many thanks
Erm, same here on Fedora 22, including the inability to fix as per FAQ recommends. Appending offscreen-false won't do the trick.
Actually, I only need metric measures enabled - is it possible to do it manually?
I also need to only change the measurements system to metric (the international). How to do it? Editing some config file?
java -jar /usr/share/java/sweethome3d.jar -Dcom.eteks.sweethome3d.j3d.checkOffScreenSupport=false
Doesn't work.
Arch Linux, jre8-openjdk 8.u66, sweethome3d 5.1
Doesn't work.
The web method worked.
I installed icedtea-web 1.6.1, which provides javaws, then using the jnlp file http://www.sweethome3d.com/SweetHome3D-NoOffscreen.jnlp from the FAQ:
Or to just to change the measurement unit, edit ~/.eteks/sweethome3d/preferences.xml to a sane value:
<entry key="extensibleUnit">METER</entry>
or
<entry key="extensibleUnit">CENTIMETER</entry>
javaws SweetHome3D-NoOffscreen.jnlp<entry key="extensibleUnit">METER</entry>
or
Are you sure that the .jar file you tried in the command is the Jar executable file available at the end of Download page?java -jar /usr/share/java/sweethome3d.jar -Dcom.eteks.sweethome3d.j3d.checkOffScreenSupport=false
Doesn't work.
In Arch Linux, the script used to build the installable package, downloads the "Sweet Home 3D executable jar (25.7 MB, same size)" and renames it from SweetHome3D-5.1.jar to sweethome3d.jar in the /usr/share/java/ path. So it should be the same file.Are you sure that the .jar file you tried in the command is the Jar executable file available at the end of Download page?
