No 3D panel with SweetHome 4.5 on Debian Jessie
This topic has been viewed 5007 times and has 4 replies
jbernon
Post by jbernon »
When I open a sh3d file with SweetHome 4.5 on Debian Jessie through Gnome 3.14.1, I can only display de 2D panel. Here are the log messages. Who can suggest anything ?
Apr 20 18:49:51 pc-jean-debian sweethome3d.desktop[3760]: Java 3D: implicit antialiasing enabled
Apr 20 18:49:54 pc-jean-debian gnome-session[1047]: Window manager warning: Invalid WM_TRANSIENT_FOR window 0x20000ac specified for 0x20000b1 (Mises à j).
Apr 20 18:50:37 pc-jean-debian gnome-session[1047]: Window manager warning: Invalid WM_TRANSIENT_FOR window 0x20000ac specified for 0x20000b1 (Mises à j).
Re: No 3D panel with SweetHome 4.5 on Debian Jessie
Use Ubuntu or Kubuntu 14.04 LTS.
I tried Ubuntu Gnome 14.04 and couldn't get SH3D to work at all.
jbernon
Post by jbernon »
Thank you for your answer Hans.
I can already use Sweethome through Windoxs 7. I would like to use it through my Linux dist which is the new Debian 8 release (kernel 3.16.2). Using Ubuntu 14 for one app doesn't make sense in my environment.
I will try again to make sh3d working with Debian 8 (also called Jessie). sh3d is part of the main dist packages and it should work. Here are the Debian packages :
- sweethome
- sweethome3d-furniture
Here are the sweethome package dependancies :
- icedtea-netx-common | sun-java6-bin
- javawrappers
- libfreehep-graphicsio-svg-java
- libitext-java
- libjava3d-java
- libsunflow-java
- libbatik-java
- default-jre | java6-runtime
In your opinion, what is to be checked in this stuff ? Is there any probability to get it working ?
I've never used Debian, so what I'm telling you is about past experiences with Ubuntu.
You could try:
- Read the FAQ, there's a note on 2D-3D problems linked to hardware
- Update your graphics driver
- Uninstall all versions of Java and install Oracle Sun Java
- Finally, if the installed version of SH3D doesn't work, maybe the webstart version does.
Good luck.
jbernon
Post by jbernon »
Thanks Hans,
I already succeeded to run my file and get 3D panel with the web version. I just had to install the java plugin of iceweasel. This was not part of the standard installation.
I will look later at the local running, but I will give a return.
Bye
