Just installed v. 4.6 and all seems to be working well except that, and I am following the instructions in the provided help area, once I select a room (it's a single, 4-walled room) the Modify Room function in the Plan/Modify Rooms drop-down remains grayed out and unusable.
I'm sure it's something simple but I cannot find the answer.
Any clues appreciated. (My end goal is to get that window that allows me to create floors/textures and ceilings as well)
Thanks!
Modify Room Function Not Working?
This topic has been viewed 5070 times and has 3 replies
Altstatten
- Country: Carrollton, Texas, United States
- Contact:
Re: Modify Room Function Not Working?
If you draw four walls, the space inside may look like a room, but for the program it is NOT a room.
To create a room, use the Create Room button, right next to the Create Wall button.
[email protected]
- Country: United States
I'm having the same issue and I already created the room.
Do you mean you created a room with the Room creation tool, set the Select mode back and when you double click on the room nothing happens?
