How to build some floor?
This topic has been viewed 8713 times and has 4 replies
Tiso
Post by Tiso »
Hi there,
maybe my problem was discussed many time, but searching for a solution I didn't find what exactly I wish.
1) I have realized the first step with this wonderful software: one floor with some rooms, but I would like to make also the second floor and I have noticed that there is not any panel or something that can help me on what I would draw. I have thought to take one plane adapting to my project, but I don't know if it is the right solution.
2) In the first floor (ground floor) I have two problems:
---a) how can I put one texture on the floor if there is not one?
---b) my project need to put the floor up from the ground for three steps, but the solution recall the first point.
Thank for any answer.
Re: How to build some floor?
Did you read the User's Manual ?
- how to make rooms
- how to add a level
Tip:
- level 1 = ground floor and 3 steps
- level 2 = main floor
- level 3 = second floor
Tiso
Post by Tiso »
Thank for your answer, but I'd already read the manual, but it isn't clear how to create the floor dividing from main-floor to second-floor, I mean where you walk. Have I using one plane adapting the dimensions as a floor?
Tiso
Post by Tiso »
Thank for your support, I will take a look.
