Cannot render in level 4 (best)
This topic has been viewed 8895 times and has 10 replies
kurucom
Country: Alanya, Turkey
Post by kurucom »
My computer has:
AMD FX8320 (8 core @ 3.5 GHz)
AMD 280X (3 GB)
16 GB RAM (4x4 GB)
256 GB SSD (Ocz Vertex 4 - only 1 partition and 109 GB empty)
4 TB HDD (Seagate barracuda 7200.14 - only 1 partition and 806 GB empty)
Windows 8.1 64 bit (very stable and has all updates)
Java version 8 update 31 (64 bit)
SweetHome3D.l4j.ini contains 2 lines
-Xmx16384m
-Xms3072m
I am trying to render in best level but cant do it, even small object (fx. only one table in scene)
Level 1, 2 and 3 works fine but on 4 (best level) nothing happens
Sorry for my bad english....
Re: Cannot render in level 4 (best)
What does Help --> About say?
Something like:
Java version 1.6.0_45 / 32 bit / 0.6 GB max
kurucom
Post by kurucom »
Something like:
Help -> About Says:
Java versiyonu 1.6.0_45 / 64 bit / 14,2 GB max
Where did the table come from? Wouldn't you have used a too large image as texture somewhere?
kurucom
Post by kurucom »
I dont remember, I have too much objects imported from Sketchup, 3DMax etc....
But I am trying to render what I seen in this forum happens nothing.
I am creating new file with only one table it hapens nothing to.
Send [url=mailto:[email protected]]me[/url] your file if you want. Maybe you encountered a bug.
kurucom
Post by kurucom »
Sent... Thank you very much...
I've been trying your file on my iMac with no issue using -Xmx2250m.
Could you try again with Sweet Home 3D version 4.6 and no SweetHome3D.l4j.ini file?
kurucom
Post by kurucom »
Finally found the problem
I changed only Language and now everythings work.
Maybe you should check language file.
Would you use Turkish localization?
Last week, after releasing the version 4.6, I found a bug that prevented to run the rendering at the best quality with Turkish localization. Correction will be available in the next version. Sorry for the issue. If you prefer to run Sweet Home 3D in Turkish, I can provide a patch if needed. Just open a bug ticket and I'll post the patch there.
