cant create video
This topic has been viewed 7637 times and has 3 replies
cant create video
Hello to all. Im just new at this forum. Im using ubuntu14.10 and sh3d 4.4 . I cant record a video on linux, the button is just grey. On W7 i can make a video.But i wanna use linux. a reinstallation brings the same issue. does anyone got an idea whats the problem ? THX for your help
Re: cant create video
A grayed out video button generally indicates a video driver problem.Try to find a better driver.
The only other problem I have encountered with Ubuntu 14.04 is a Java conflict. If that is the case, uninstall all Java, and then install the original Sun Java.
Under the version distributed through Ubuntu repository, the menu is grayed because the respository team removed the JMF library required to generate videos. This library is free but not open source, that's why they consider it shouldn't appear in the repository.
If you want this feature, just use the free version available from download page.
This JMF library, is that something that must be packaged with the application, or could it be installed separately, either manually or in a separate -nonfree package?
On a separate note, I have requested the GetDeb packagers to include the library in their build: https://bugs.launchpad.net/getdeb.net/+bug/1599706
