[font=times new roman]Good afternoon
I have a two levels design, when I have active the second level in the 3D view also sees the first level.
I can put the floor/ceiling opaque to prevent this happening?
Thanks in advance[/font]
Techo/Piso
This topic has been viewed 2790 times and has 1 replies
Re: Techo/Piso
Maybe I misunderstand, but did you add rooms with the room tool (Plan-Create rooms / Ctrl+Shift+R)? If not, draw a room. Or if walls are connected/overlapping around a room, just double-click inside the walls. Then you will have (opaque) floors/ceilings.
PS Hiding the lower levels from the 3d view is not possible, it is either all levels or current level + all below.
