angry High priority Wall Creation
This topic has been viewed 3016 times and has 3 replies
choppyleo
Country: Yaounde, Cameroon
Wall Creation
Post by choppyleo »
Is there a possibility of creating a wall which is not completely covered that is the wall contains holes. I guess such wall is used to ease ventilation. I will love to use that in my house but can't see it in sh3d or its models.
Thanks
Re: Wall Creation
From this page you can import models like box, triangle, cylindrrs, etc.
During importation, make sure to check Doors/windows.
If necessary rotate them into the correct position.
Now you can insert these objects in a wall, and they will give a hole of the desired shape.
choppyleo
Re: Wall Creation
Post by choppyleo »
Thanks Hans, I tried but the cylinder is not open at both ends so eventually I cannot obtain holes. can somebody help me with an object cylinder open at both ends
Re: Wall Creation
- Search the Sketchup Warehouse.
- Search the forum for invisible boxes, cylinders, etc or how you can make any object invisible by manipulating the MTL file.
cylinder invisible.zip
(1.86 KiB) Downloaded 929 times
