Is there a maximun file size for sh3d files?
This topic has been viewed 4158 times and has 6 replies
Lately I've added a lot of new objects by grouping and texturing boxes and cylinders into custom objects. The sh3d has grown to 67.794 kB. Now I can't render pictures anymore, the rendering just freezes in the inital phase.
Re: Is there a maximun file size for sh3d files?
Try these:
- read the FAQ and do the XMX trick
- delete half of your models, then try to make a render; if it works, probably one of the deleted models is faulty. If not, restore your deleted models, delete the other half, and repeat the procedure.
The XMX trick did the trick partially. I can now render a picture but can't save it. Th program freezes at that poit, will try deleting models tomorow.
Do you use a 32 or 64 bit system?
I have Windows 7 64 bit. Until this week I din't have this problem...
Why happens when you try to save the image?
That's just what bothers me, why a freeze when I only want to save the rendered picture?
