I have a living room wall that has stone on the bottom half, and is painted on the upper half. How can I apply two textures to the wall?
Can I create two walls, one on top of the other, and apply textures to each?
Should I apply the stone texture to the wall, and then create a very thin box, the dimensions of the upper half of the wall, and apply the paint texture to that?
Is there a better way to do this?
Thanks.
Two textures on one wall
This topic has been viewed 5696 times and has 3 replies
Re: Two textures on one wall
Method 1 - As you suggested: use a thin box for the lower part
Method 2 - Insert a level and draw walls for lower and upper level, each with a different texture. (Method 1 may be simpler.)
Because I had a cutout for a fireplace in the lower part of the wall, I made the whole wall stone, and put in a thin painted box for the upper part.
Thanks, again!
Thanks, again!
Method 3: use a lower wall (instead of a box) next to the higher wall - or just make it slightly thicker if you have stone on both sides. With this approach you need not worry about a new level, and it is easier to match the geometry of two walls than a wall and a box.
Method 4: edit your (stone) texture adding the painted area on top, make sure proporsions are right, and import texture setting texture hight = wall height.
Method 4 would be my preferred option as you can apply the same texture to many walls at the same time and it is easier to edit the sh3d walls later.
