When I insert Window (Furniture Item made by myself) to the Walls, There is no opening coming Automatically in the walls like inserting the doors and windows in the sweethome itself ?
Openings in Wall
This topic has been viewed 4264 times and has 3 replies
Re: Openings in Wall
If you are using a model that you imported yourself, you have to check Door or window in the second step of importation.
Did you remember to cross off for Door or window when importing your model? If you did, SH3D should indeed make an opening equal to the shape of your model. ok
Many Thanks......
