HELP !
This topic has been viewed 3175 times and has 3 replies
hosein7770
HELP !
Post by hosein7770 »
How can I draw a round wall in the best way possible
I'm going to draw the wall I'm enclosing.
Re: HELP !
How about this? ok
hosein7770
Re: HELP !
Thanks a lot.
Re: HELP !
Just for the completeness of the reply in case someone wonders (like I used to):
  • Walls have an Arc extent property that will curve a wall (+/- values).
  • The easiest way to draw a room within a curved wall, is first to draw the walls, and then double-click with the Room-tool. Then the room will follow the wall.
  • Rectangular windows and doors can be inserted in curved walls, but must be placed manually: adjusted depth so they penetrate the wall and exact angle to follow wall (use Alt to disable magnetism if you use mouse).
