It would be nice if we could give a start and end ground elevation.
It would also be nice if we could give sloping walls not only from the top but also from the bottom.
Another missing feature is to create a movie from Aerial perspective.
Thanks all for great software
ground elevation and sloping wals
This topic has been viewed 6941 times and has 1 replies
Re: ground elevation and sloping wals
Sloping terrain would be a nice feature that would have helped my mountain project initially. But, as you have probably figured out, there are several workarounds. See this link (4817) and more.It would be nice if we could give a start and end ground elevation.
For those rare occasions, don't you think the (fairly) straightforward workarounds will suffice? Such as:It would also be nice if we could give sloping walls not only from the top but also from the bottom.
- Drawing a sloped wall, export as OBJ, import and rotate.
- Using an invisible triangle (or whatever) imported as a window/door to make a cutout in the wall.
Just my 2p worth. ok
