I use a lot of arcs in my designs and it would help to be able to see the angles that are used between the guidelines that limit the arc.
I use dimension lines to point to the arc centerpoint and guidelines out to the actual arcking wall to remind myself the distance to this centerpoint. I could use an angle indicator near the centerpoint to see the total angle the wall is arcked.
Angles in dimension lines
This topic has been viewed 4990 times and has 0 replies
