hallo,
could use some help.
I want to make some real photos of my architectural model, and later a video.
My problem is that in the best-quality stage, the image calculation 400x600 pixels stops me again and again even at a resolution of approx. The model is also very detailed. It has about 500mb.
What can be wrong? Or what can I do?
I tried to give more main memory, but it doesn´t work i my opinion. I see in the Windows task manager, that the cache use only to 3mb.
Mayby I do it not correctly, but I tried more scopes
My laptop has Intel Core (TM) i7 processor and 6 GB of RAM, Windows 7 (64 bit) and an NVIDIA GeForce graphics card as GT330MM
Thank you for your help
Can´t make photografie
This topic has been viewed 2523 times and has 2 replies
Re: Can´t make photografie
First, just to be sure what you run:
Do you use version 4.3?
If yes, does the 3rd line of the About dialog show 32 bit or 64 bit?
Does the 2nd line show Java Web Start or not?
Hallo,
thanks for help.
This was the reason, why it didn´t work.
The old version!
Thanks a lot!
Best regards
thanks for help.
The old version!
Thanks a lot!
Best regards
