adding texture to a box
This topic has been viewed 4064 times and has 4 replies
petefastfeet
Post by petefastfeet »
Hello all,
When I add a texture to a box, it stretches the texture image to the size of the box face, as opposed to replicating the image....any thoughts what I am doing wrong?
Re: adding texture to a box
Textures applied to the box provided with Sweet Home 3D behave differently according to the way you selected the textures:
- if you apply a texture globally on the box, i.e. by selecting a texture directly from the Modify texture dialog box, then the size of the texture will be taken into account and will be truncated or repeat itself, depending on the size of the box
- if you apply a texture on one or more faces of a box, i.e. through the Furniture materials sub dialog box, then the texture will be resized to fit the given face(s) of the box.
petefastfeet
Thanks for the quick response. I see now how it works, thanks.
ndorigatti
Country: Italia
Post by ndorigatti »
Hi, sorry for resuming this but I have a question on this...
I want to draw wood pieces for an attic and those have the texture of different angle of different textures on sides, so I would like to create a box and repeat the texture on their sides, so what I'm asking is if I can do with blender or other software, because I tried but Did not manage to do, reading this post seems that is due to the sweet home behaviour and not on my models, am I right?
You can't prepare texture mappings in Blender that won't stretch textures in the exported OBJ file when you resize your imported piece.
But you could use 3 (or more) boxes instead of one in Sweet Home 3D, one for the 4 front/top/back/bottom sides, and 2 (or more) thin ones for the left and right sides. Once grouped, the textures on the boxes will behave as you expect it when you resize the group (see the file attached to this post).
BeamWith3Boxes.sh3d
(64.98 KiB) Downloaded 329 times
