terrace, hanged wall
This topic has been viewed 3239 times and has 3 replies
kempher
Post by kempher »
Hi, i am a newbie in this forum, may somebody can help me. How to create a hanged wall in terrace up side, because i try to make it with the wall, not feature to change elevation which is can make the wall move higher, i need solution an thank you [:((]
Re: terrace, hanged wall
Provided I understand your question, how about: Either create a new level where you want the wall to be elevated, or use an invisible box or opening to remove the lower part of the wall.
kempher
Post by kempher »
Thank's man, i'll try to find 3d model of invisible box, recommended extention file of invisible box may .obj or....?
Creating an elevated level (even if it is just for that wall) would be my preferred solution.
For a box, you can use this (zipped .obj - drag drop into plan) - just make sure you import it as a door/window so it cuts a hole in your wall.
