Plugins don't save a file on disc
This topic has been viewed 5867 times and has 1 replies
kupiecu
Country: Warsaw, Poland, Polska
Post by kupiecu »
sorry, my english level is low.'
I write plugin. It write walls, rooms and furniture to OBJ file. It's work but only when I debbuging this plugin. When I run it normally the plugin don't save file on my disc. ( when debug the file is saving ).
I have no idea, any sugesstions? Mayby samethink like permissons or samethin in manifest file? I don't now. Please help.
import java.io.IOException;
import com.eteks.sweethome3d.j3d.HomePieceOfFurniture3D;
import com.eteks.sweethome3d.j3d.OBJWriter;
import com.eteks.sweethome3d.j3d.Room3D;
import com.eteks.sweethome3d.j3d.Wall3D;
import com.eteks.sweethome3d.model.Home;
import com.eteks.sweethome3d.model.Room;
import com.eteks.sweethome3d.model.Wall;
import com.eteks.sweethome3d.plugin.Plugin;
import com.eteks.sweethome3d.plugin.PluginAction;
import javax.swing.JOptionPane;
public class Wtyczka extends Plugin {
	@Override
	public PluginAction[] getActions() {
		return new PluginAction[] { new VolumeAction() };
	public class VolumeAction extends PluginAction {
		public VolumeAction() {
			putPropertyValue(Property.NAME, "Upload project on your android device");
			putPropertyValue(Property.MENU, "ToucHHome");
			// Enables the action by default
			setEnabled(true);
public void execute() {
OBJWriterTest ogien = new OBJWriterTest(); // obuekt stworzyc
		try {
			ogien.testOBJWriter();
		} catch (IOException e) {
			// TODO Auto-generated catch block
			e.printStackTrace();
		public class OBJWriterTest {
			public void testOBJWriter() throws IOException {
				Home home = getHome();
				    // 1. Open the OBJ file "Test.obj"
				    OBJWriter writer = new OBJWriter("dragsy.obj", "Test", -1);
				   // assertTrue("trots.obj not created", new File("trots.obj").exists());
				   //write walls
				    int i =0;
				    for (Wall wall : home.getWalls()) {
			            // Create a not alive new wall to be able to explore its coordinates without setting capabilities
			            Wall3D wallNode = new Wall3D(wall, home, true, true);
			            writer.writeNode(wallNode, "wall_" + ++i);
				    // Write 3D rooms
			          i = 0;
			          for (Room room : home.getRooms()) {
			          Room3D roomNode = new Room3D(room, home, false, true, true);
			          writer.writeNode(roomNode, "room_" + ++i);
			        //Write 3D furniture
				        for (HomePieceOfFurniture piece : home.getFurniture()) {
				         // if (piece.isVisible() && objFile.equals("." + File.separator + "My_Home" + File.separator + piece.getName() + ".obj")) {
				        	if (piece.isVisible()){
				            // Create a not alive new piece to be able to explore its coordinates without setting capabilities
				            // I set as home = null
				            HomePieceOfFurniture3D pieceNode = new HomePieceOfFurniture3D(piece, home, true, true);
				            writer.writeNode(pieceNode);
				    // 3. Close file
				    writer.close();
Re: Plugins don't save a file on disc
Writing files in a plug-in doesn't work if you run Sweet Home 3D under Java Web Start.
If this doesn't apply to your case, you should try to save the file dragsy.obj in a directory where you're sure you have the rights to write.
