Hallo-Hallo, i'm creating apartment, where i will be live. But my apartment will be on 18th floor, and i want to creat around "blue sky" view, so no needed earth under apartments.
How i can done that? please help.
Thanks.
No needed earth around apartments, how up my apartments in sky? : )
This topic has been viewed 3236 times and has 1 replies
Re: No needed earth around apartments, how up my apartments in sky? : )
Depends a bit on what you want from your perspective, I suppose.
How about making a first level very high, draw a rough outline of your building with high walls and add your flat on a new level on the 18th floor? The horizon will not appear much lower, though. (It doesn't in the real world either, just farther away.)
Also, you can apply shades of blue to both ground and sky, but you may need to use a darker shade of blue on the ground. (Using textures is more difficult as they are stretched differently on sky and ground.)
