Hi
I am quite new here and have no much experience.
I was trying everything in order to create the stairs with the angles i wanted.
I couldn't find any aproperiate model and therefore I created stairs with "box" stair by stair....
now I desperetely need a rail. and preferbly made out of glass.
How can I create an adjusted rail?
stairs rail
This topic has been viewed 6414 times and has 2 replies
Re: stairs rail
Compliments on doing a box stairs. Good idea. To your glass rail question, there is no easy answer (that I can think of). But maybe you could use something like this (stair_rail_glass.zip)?...desperetely need a rail. and preferbly made out of glass.
Probably needs some stretching and patching.
Re: stairs rail
BTW: you could also put a thin, sloping wall next to your stairs (modify start and end height). But it wouldn't solve your glass and rail problem. As you need to fit it to a specially angled staircase, you may have to look into using 3d model software to get the measures and angles right.
