sad Problem with video on Ubuntu 12.04
This topic has been viewed 3774 times and has 0 replies
pabloyepes
Country: Houston, Texas, USA
Post by pabloyepes »
When I try to produce a video with the latest version and Ubuntu 12.04 I get the following error:
# SIGSEGV (0xb) at pc=0x00007fd874261ae8, pid=2682, tid=140566597400320
# JRE version: 6.0_45-b06
# Java VM: Java HotSpot(TM) 64-Bit Server VM (20.45-b01 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C [libX11.so.6+0x33ae8] XQueryExtension+0x28
# An error report file with more information is saved as:
# /home/yepes/hs_err_pid2682.log
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
# # A fatal error has been detected by the Java Runtime
Any ideas what the problem may be.
Thanks,
Pablo
