I would like to be able to draw a cavity wall and also add cavity filling (cavity wall isolation).
Obvously I can simulate a cavity wall drawing several walls, but this doesn't cope with windows and doors etc. (I think).
So I would like to know if such kind of wall exists and can be used as a single object (prefereable allowing to change/size cavity filling)
Cavity wall isolation
This topic has been viewed 5505 times and has 1 replies
Re: Cavity wall isolation
SH3D doesn't have cavity walls.
You can (easily) make them yourself by drawing 3 parallel walls. I suggest using exact X,Y coordinates to avoid overlapping.
To insert walls and doors, use this trick:
1 - insert a (suitably thick) hatch or an invisible box by using CTRL + ARROW KEY. This will pierce your walls.
2 - using the same method, insert a door or window. This has the added advantage that you have more control over the placing and thickness of your door/window.
