How to define the fitting part of a door or window
This topic has been viewed 4656 times and has 3 replies
hal9000
Country: Spain
Post by hal9000 »
I have seen that the open door object, although its surrounding box is thick to include the open leaf, only uses the part of the frame to fit it to the wall where you'r putting it.
How can I define such "fitting box" for a model exported by me from Google SketchUp, for example? If I just take a model of open door exported by me, then SH3D takes its full size to adjust to the wall, compressing the open leaf with weird results. [:(]
hal9000
Country: Spain
Re: How to define the fitting part of a door or window
Post by hal9000 »
Oh, I forgot something related. When I insert one of the included doors it appears on 2D correctly drawn as a door, but when I use a door imported then it appears as a solid box.
Is there a way to prepare a custom model for it to be drawn correctly as a door?
Angel,
You may want to read this message.
hal9000
Country: Spain
Post by hal9000 »
Oh, it seems like I didn't use the correct search terms. [:))]
Thanks Hans!
