vertical diagonals
This topic has been viewed 2430 times and has 2 replies
oldgreybeardloon
Country: sydney, nsw, au
vertical diagonals
Post by oldgreybeardloon »
Hi all
Is it possible to draw vertical diagonals, ie., frame crossbracing?
If not specifically, then perhaps a sneaky workaround?
Re: vertical diagonals
The workaround would be to use a box or a cylinder found in the miscellaneous category, resize it to make it look like a beam, export it with the 3D view > Export at OBJ format menu item, then import the export file with the Furniture > Import furniture menu item, and fine tune its orientation at the second step of the furniture import wizard using the Shift key + arrow buttons.
oldgreybeardloon
Thank you Emmanuel, Magic!
