Ocatgon v3
This topic has been viewed 10458 times and has 1 replies
Llewelyn
Country: Llanwrda, DYF: Dyfed, United Kingdom
Ocatgon v3
Post by Llewelyn »
version 3, calculated correct dimensions for a regular octagon and changed the way I drew it slightly, the roof still isn't perfect but now the same roof section doesn't quite fit all of it [:)] Also got some better textures and did a bit more decorating, but ran out of inspiration for a couple of rooms. Ah, and I see I left one patio door in the wrong place. Can't select a wall section without moving it, as it covers the entire section on the plan.
Re: Ocatgon v3
It's time to use the Select Object contextual menu to select the object where you right clicked in the plan. [;)]
