Rendering Problem
This topic has been viewed 4664 times and has 5 replies
shet
Rendering Problem
Post by shet »
I have a problem with rendering, for example, transparent or semitransparent curtain. See my presentation set in the attachment.
Thanx for replies.
shet
Re: Rendering Problem
Post by shet »
You should try to play with the color of the object, not only with its opacity factor.
For your information, as you'll see in this post and previous ones in the same thread, translating OpenGL transparency to SunFlow transparency (i.e. rendering engine at the two best quality levels) wasn't so easy, and it took a while to find acceptable values to render existing 3D models. Feel free to change them in the source code if needed.
shet
Post by shet »
For this time I Thank you. I will try.
shet
Post by shet »
Nothing better.
If the object is plane, there is no problem, but "wave" object with d < 1 makes me trouble. Nothing helped me. I used manual for MTL http://paulbourke.net/dataformats/mtl/ but without success. Any suggestions?
shet
Post by shet »
I found no way to do that via transparency, but when i applied semitransparent texture to object, it is OK. But very hard way to render such an object for CPU :-(
