I read the tutorial and was able to draw a building complete with a roof.
I created the roof in a separate window and then brought it in as furniture.
My problem is that at the end of the roof is a large gray square block.
I had the same problem on my last project. When I put in a triangle window, a large square chunk was taken out of the wall.
I am sure it has something to do with blocks coming in as a rectangle.
How can I get rid of this block? I wanted to make a picture out of the model but the block goes right on top of the building.
I can post the file if it helps.
Thanks .... Mike
roof has block at end of it
This topic has been viewed 5830 times and has 1 replies
Re: roof has block at end of it
This sounds like you exported/reimported a design with walls which contained a ground part automatically generated.
Please read this post for a solution.
