Hi There!
This great open source app really rocks!
[=D>]
But if I try to print my 2D view or even save it to a PDF, all the lines happen to be very bold. Is that normal? How can I get the lines to be as skinny as in the normal 2D view? [:-/] [:-/]
For now, I'm using a workaround in taking screenshots and printing them, but it would be nice to have a proper solution.
Printing / PDF
This topic has been viewed 2888 times and has 2 replies
Re: Printing / PDF
Did you try with a different scale?
An other proper solution would be to export your plan to SVG format, or copy/paste the plan in a drawing program or the document where you want to use it.
Re: Printing / PDF
Yes I've used different scales, didn't help.
But I didn't know about the copy/paste workaround; this works just fine! Thanks for the tip!
