Again about transparency
This topic has been viewed 6169 times and has 4 replies
macsg
Post by macsg »
I know this topic has been managed several times, but I have a very strange problem: when importing obj or dae objects, the transparency of materials seems to be appropriated according to given value in 3d view but is very attenuated in the final rendering. In other words, with d 0.99 (almost full opaque) the object is shown as completely transparent in final rendering... COuld you please give me a suggestion?
Thanks
M.
Re: Again about transparency
You should use a darker color for the object too. See this thread for examples.
macsg
Post by macsg »
Well, I tried with fully black material(instead of gray glass), but the transparence is not really sadisfing me, it seems to be just a shadow on the back objects... In my case, I saved as collada or obj any of the following Ikea Besta object, with glass door:
http://sketchup.google.com/3dwarehouse/ ... 8639c89784
But the results are very poor, even changing the d parameter (that is correctly generated by sketchup export engine) or changing the original material in several way: using colored or fully black.
Could you please tell me what's wrong? I'm spending my nights on it..
Many thanks
Regards
Massimo
Sorry, I did my best to make transparency work in SunFlow rendering engine, even if its last release didn't support it fully.
As users can import furniture from many sources, I don't think I can do better in a close future. If it doesn't satisfy you, I guess you'll have to export your home at OBJ format to render it in an other software, or give up Sweet Home 3D.
macsg
Post by macsg »
Well, just to avoid misunderstandings, I really appreciate your effort and your timely and effective support. Unfortunately I'm not professional user and I'm not deeply into the matter as well. I found your product very useful and easy to use compared with other sw like eg. Chief Architect. Thanks again.
Massimo
