Is there a downlighter light source around anywhere? I've sort of faked one up by putting a light source in a tube but the effect doesn't match what I expect to see.
TIA
downlight light source?
This topic has been viewed 5292 times and has 2 replies
Re: downlight light source?
Using light sources should be enough, unless you want to display them turned off.
I assume a light source model is a point source with equal intensity in all directions? Downlighters have a limited angle (MR16 bulbs are 36deg to the 50% points I think). So a 180deg source will not give the same effect. Is it easy to make a light source with varying intensity?
