This topic has been viewed 4713 times and has 7 replies
Thread status:
Active
klgan
Posts: 12 Joined: Thu Oct 25, 2012 10:20 am
Post
by klgan » Thu Oct 25, 2012 11:48 am
How to add or remove part of the floor? For example when you have a round wall, how to add a round floor for it? The two images below should make my question clearer?
Please share how to do it. Thank you
Posts: 9440 Joined: Mon Nov 07, 2005 12:00 pm
Post
by Puybaret » Thu Oct 25, 2012 2:52 pm
Did you try to create rooms by double-clicking in the area within walls? This will take into account the round walls.
Gaytan
Posts: 41 Joined: Mon Oct 08, 2012 4:26 pm
Post
by Gaytan » Thu Oct 25, 2012 9:31 pm
Hi Emmanuel,
As you know I work on an iMac with latest Mountain Lion. I've got Apple's trackpad as well as Kensington's trackball mouse connected, for more precise manipulations.
Double clicking within a 'closed area' in order to create rooms has never worked on my system unfortunately!
Do you have any hints or tips?
Kind regards,
Ed
klgan
Post
by klgan » Fri Oct 26, 2012 6:05 am
Good gracious! it is that simple, double click between walls...
Yes it works, thank you very much Puybaret
Post
by Puybaret » Fri Oct 26, 2012 8:30 am
klgan, great it worked for you! [:)]
Ed, maybe the areas you tried to click into weren't surrounded by a
closed area of walls. Could you send [url=mailto:
[email protected] ]me[/url] a SH3D file where it didn't work?
Gaytan
Post
by Gaytan » Fri Oct 26, 2012 10:24 pm
Emmanuel,
Just to confirm that 'double clicking' within a 'closed area' now works. Guess it has to do with the new version?
Problem solved!
Rgrds,
Ed
Post
by Puybaret » Fri Oct 26, 2012 10:44 pm
Ed, I'm glad it worked for you. I fixed a bug recently and you're right, this could be the reason why it didn't work before in your case. [;)]
Gaytan
Post
by Gaytan » Mon Oct 29, 2012 9:10 am
Ok, nice!!
No problem; I don't mind doing the floors and walls 'manually' but by double clicking, things do go faster; that's a fact!
Nice!
Thank you Emmanuel!
