Good day, i am planning to renovate my house with a basement level, my problem is how can i create the walls of the basement and ground level walls with different dimensions & location as well as the ground perimeter walls, i have downloaded and installed all the software at the download section.
How will i create the ground level on top of the basement level, thanks in advance for the assistance, newbie here.
2nd level walls
This topic has been viewed 3193 times and has 4 replies
Re: 2nd level walls
Joey,
Use the function Levels with a negative elevation.
Re: 2nd level walls
Sorry sir but i cant find or dont know how to go to or use the function levels, can you point me to a more precise instruction, i just so happen to use the program for the first time, thanks again for your kind assistance.
Re: 2nd level walls
Re: 2nd level walls
Sir,I just so happen to the section your pointing out here, reason why i can find the split level thing is that i have installed the old version, when you replied about the split thing and cant find it i then tried downloading the latest version and now i am learning more in using the latest version and was able to toy around split level or adding new level.
Again Sir thank you very much for your very kind assistance, i am still in the process of learning what i can do with this free software.
