photography level 3 and 4 problems
This topic has been viewed 6968 times and has 10 replies
salva.segui
Hello to everybody,
If I create a photography at level 3 or 4 I get a result full of shadows around the building (floor grey/dark)and a very bad resolution, during the process of the project I work step by step saving every couple of hours my work on diferent files.
Starting a new project from cero I don´t have this problem but after some modifications the problem appers and then is thear for always.
Any idea??
[img]C:\Documents and Settings\salvador\Mis documentos\Mis imágenes\foto error.bmp[/img]
Any idea??
Re: photography level 3 and 4 problems
The shadows are different in aerial view mode and virtual visit mode. This was programmed this way because of a bad rendering effect in some cases.
salva.segui
Thanks for your answer Mr. Puybaret
Sorry, I have not been clear with my explanation,then...
You know how can I add a picture of the problem on this post for show you better the problem?
Thanks
Thanks
salva.segui
photography
salva.segui
[img]C:\Documents and Settings\salvador\Mis documentos\Mis imágenes\Dibujo1[/img]
salva.segui
I'm sorry, I'm try to add a photo for show you the problem but I can not, can I send you it by e-mail?
Thanks
Thanks
Please have a look to this subject to help you add a photo to a message.
salva.segui
Here you have¡¡
Thanks a lot
Thanks a lot
salva.segui
There you can see that the 3D view is a clean view without shadows.On the photagraphy, you can see how are the floor shadows and strange figures never I designed or planned.
This may happen if the building is very very very large.
Can you check the size of your plan? From the image you posted it shouldn't be larger than 100 meter long, and the effect you reported should happen if it's larger than 500 meter.
If you work with imperial system, maybe you mixed feet and inches.
