Hi there.
I use sw3d with 2 different computers and on each one I have some furniture but There are some diferences
I'd like to keep both machines with the same configurations and same furnitures, templates, etc.
How Can I do that?
Both machines are runnig W7
Tks
Clovis
How to keep instalations =
This topic has been viewed 5421 times and has 6 replies
Re: How to keep instalations =
Clovis,
Did you try using the function Furniture -> Export imported furniture to SH3F ?
The easiest is to copy the content of the content of the directory
C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D\furniture
from one computer to the other.
Doing the copies all the furnitue will be imported, OK!
And about the textures for cealings and floors? wuere are the files to be copied?
TKS
Clovis
TKS
Clovis
Sorry I should have wrote to copy all the content of:
(the work subfolder which might might be quite big is not necessary).
Puybaret Hi
I toke a look at mi machine and did not find this sub/folder
On my machie I Have the fololoing folder:
C:\Users\Clovis\Application Data\eTeks\Sweet Home 3D
and inside this folder has :
furniture (folder)
recovery (folder)
works (folder)
and a lot of archives caled furniture-3-xxxxxxxxxxxx.pref
On APP data there is not a eTeks folder
coping the finded archives will resolve my problem?
Thanks again
Clovis
furniture (folder)
recovery (folder)
works (folder)
Thanks again
Clovis
If there isn't a C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D folder in your destination computer, open Preferences in Sweet Home 3D on that computer and change any value to create it.
Then copy all the content of the Sweet Home 3D of the original computer to the destination computer, excluding the work sub folder but including the *.pref files.
