I'm newbie but I really appreciate this program is helping me a lot to plan my new house.
I could manage to make the plan based on an existing one, but I just found a problem that would like to put it here.
The house will have only a ground level (no 1st floor), but the ground has two levels the back of the terrain/ground is higher 1,20mts and the front is 0mts.
How can I do this ? [:-/]
Many thanks
Ground levels
This topic has been viewed 8462 times and has 2 replies
Re: Ground levels
Leonel,
Since version 3.4 you can use Plan -> Add level.
This allows you to design one part of the house at level +0 cms, and one part at level +120 cms.
You can then surround the house by triangles and boxes that mimic the sloping terrain.
See the example I made.
- Attachments
- sloping terrain.sh3d
- (17 KiB) Downloaded 835506 times
Re: Ground levels
Hi Hans,
Thank you for your kind answer.
I think that's all I need, I will give a try based on your example.
Thanks
Thanks
