imported glass not transparent
This topic has been viewed 6566 times and has 9 replies
I have recently upgraded Art Of Illusion, which I use to make my models and I used to make glass and export it as an obj and the glass would be transparent (after having assigned a transparent texture to it). Using this new version of AOI (2.9) when I export a glass (tried it with a material and without a material) and import it into the latest version of SweetHome3D (3.4) the glass appears either gray or black, no transparency at all.
I don't know if the problem is with A.O.I. or SweetHome3D. How can I tell? And how do I fix this?
Re: imported glass not transparent
Modifying the furniture, you try to use color, instead of using the textures.
It needs to increase transparency in the next version of the floor, Transparency of separate wall and floor.
After playing around with this all day, I found that I had to go back to using this (the old way) by opening the .obj in a text editor:
g sweethome3d_window_pane
usemtl flltgrey
ok, never mind.
If OBJ models created with a previous version of AOI are still correctly imported, it means that AOI changed something (it looks like a possible regression since version 2.9 brought changes on textures and materials). You can change it the way you did, but you can also change the value following "d" in the MTL file, 0 being fully transparent and 1 fully opaque.
If you're sure it's a bug, it would be nice to report it to AOI developer.
There seems to be no simple "d" in the .mtl file.
This is the info that AOI puts into it:
I tried making the "Kd" line as 0.0 0.0 0.0 but that did not work. I also tried it as 0 0 0 but that too did not work. The vase imported into SH3D was still black.
So, I went with:
in the .obj file.
Be expecting this vase ( http://www.storm-artists.net/view/117760 ) in the models contributions shortly.
#Produced by Art of Illusion 2.9, Mon Dec 26 16:19:27 EST 2011
newmtl Glass
Kd 0.0928 0.0928 0.0928
Ks 0.144 0.144 0.144
Ka 0 0 0
illum 2
Ns 127
So, I went with:
g sweethome3d_window_pane_vase
usemtl glasstransparent
You could add the "d" line yourself. For example:
Your vase is really nice. Thanks for your contribution. [:)]
d 0.5Emmanuel Puybaret, Sweet Home 3D creator
So, the could be placed between
and
Or should it be placed at the bottom of ?
d 0.5Code: Select all
newmtl GlassCode: Select all
Ns 127Re: imported glass not transparent
You can place the d line anywhere between a newmtl line and the next newmtl line if there are more than one material defined in the MTL file.
that worked! The glass is rather dark though. So now I have 3 versions: A light one, (usemtl glasstransparent) a medium shaded one, (usemtlglass) and now this one (using the method you just taught me).
