Background Image from command line
This topic has been viewed 6482 times and has 4 replies
kerfmas4
Post by kerfmas4 »
Hello all.
I would like to know if there is any way of execute a command to set the background image. Or command line.
I normally work with c# and before starting learning java, wanted to know if its possible to connect some simple functions like preferences,background image with c#.
Or if its possible to do programming a plugin.
The views preferences are easy to solve due to we can save a sh3d file and load through an external program renaming it.
So, what do you think will be more easy for me.
For the future I would like to integrate a little window sh3d viewer with move, zoom, just this. A form control would be perfect.
Thanks.
kerfmas4
Re: Background Image from command line
Post by kerfmas4 »
OK. Finally I've decided to learn more about java. Now I can set a predefined Jpg as backgroundimage from the menu bar.
My new question is: How could I autoload this plugin function when the application starts without clicking on the menu item?
Thanks in advance.
Welcome to Sweet Home 3D developer world. [:)]
If you want to program this only from the plugin you already created, you could set the background image of the current home in the getActions method you programmed. I guess this is not very clean, but it seems like a init method is missing in the Plugin class.
kerfmas4
Post by kerfmas4 »
First of all, thanks a lot for your help. Now the code result that worked.
package com.eteks.test;
import java.net.URL;
import java.net.MalformedURLException;
import com.eteks.sweethome3d.plugin.Plugin;
import com.eteks.sweethome3d.plugin.PluginAction;
import com.eteks.sweethome3d.model.BackgroundImage;
import com.eteks.sweethome3d.model.Content;
import com.eteks.sweethome3d.tools.URLContent;
public class SetBackgroundPlugin extends Plugin {
  public BackgroundImage ImagenFondo() throws MalformedURLException {
    URL u = new URL( "file:/c:/4683.jpg");
    Content content = new URLContent(u);
    return new BackgroundImage(content, 2500, 0, 0, 700, 700, 0, 0);
  public class SetBackgroundAction extends PluginAction {
     public SetBackgroundAction() {
       putPropertyValue(Property.NAME, "Compute volume");
       putPropertyValue(Property.MENU, "Tools");
       // Enables the action by default
       setEnabled(true);
     @Override public void execute() {
  @Override
  public PluginAction[] getActions() {
    try {
      getHome().setBackgroundImage(ImagenFondo());
    } catch (MalformedURLException e) {
      e.printStackTrace();
    return new PluginAction [] {new SetBackgroundAction()};
Thanks again.
[Note from moderator: fixed code format]
Great you succeeded!
I fixed the code format otherwise it was unreadable.
