second execute crashes the program
This topic has been viewed 6287 times and has 2 replies
jrios
Post by jrios »
Hello I use Linux Mint Julia with this kernel 2.6.38-3.dmz.1-liquorix-686.
I have got this VGA card in the laptop 00:02.0 VGA compatible controller: Intel Corporation 82852/855GM Integrated Graphics Device (rev 02)
The first time I download http://www.sweethome3d.com/SweetHome3D.jnlp and I execute this file. Then it is works. The program opens and runs well.
I close the programa and I execute again http://www.sweethome3d.com/SweetHome3D.jnlp
The program opens but crash and close it.
I execute javaws -viewer and I see that the app is installed. I drop the apps and clean the cache, then when I execute SweetHome3D.jnlp again runs well
Any ideas?
Re: second execute crashes the program
Quite a strange behavior!
You probably have two Java virtual machines installed on your system.
Unless you perfectly know how to handle this, I would give a try to the installer version.
jrios
Post by jrios »
Hello, I have download this link, unzip and execute and I have the same result. Opens the program and closes itself. With this version I drop the apps, I clean the cache but this not works.
I execute javaws -viewer and in the about version I have Oracle (build 1.6.0_26-b03)
When I execute this file (SweetHome3D) the apps splash is the SweetHome3D but the first execute the java spalsh is the Oracle.
I execute this dpkg -l | grep "java" and this is the software in my machine
ii  ca-certificates-java                      20100412                                          Common CA certificates (JKS keystore)
ii  java-common                               0.38                                              Base of all Java packages
ii  libaccess-bridge-java                     1.26.2-5                                          Java Access Bridge for GNOME
ii  libaccess-bridge-java-jni                 1.26.2-5                                          Java Access Bridge for GNOME (jni bindings)
ii  libbcmail-java                            1.44+dfsg-2ubuntu1                                Bouncy Castle generators/processors for S/MIME and CMS
ii  libbcmail-java-gcj                        1.44+dfsg-2ubuntu1                                Bouncy Castle generators/processors for S/MIME and CMS
ii  libbcprov-java                            1.44+dfsg-2ubuntu1                                Bouncy Castle Java Cryptographic Service Provider
ii  libcommons-beanutils-java                 1.8.3-1                                           utility for manipulating JavaBeans
ii  libcommons-collections3-java              3.2.1-4                                           A set of abstract data type interfaces and implementations
ii  libcommons-compress-java                  1.0-1                                             Java API for working with tar, zip and bzip2 files
ii  libcommons-digester-java                  1.8.1-2                                           Rule based XML Java object mapping tool
ii  libcommons-logging-java                   1.1.1-8                                           commmon wrapper interface for several logging APIs
ii  libdb-je-java                             3.3.62-3                                          Oracle Berkeley Database Java Edition
ii  libdb4.7-java                             4.7.25-9                                          Berkeley v4.7 Database Libraries for Java
ii  libdb4.7-java-gcj                         4.7.25-9                                          Berkeley v4.7 Database Libraries for Java (native code)
ii  libgnuinet-java                           1.1.1-4                                           extension library to provide extra network protocol support
ii  libgnujaf-java                            1.1.1-5                                           free implementation of the javabeans activation framework
ii  libgnumail-java                           1.1.2-5                                           free implementation of the javamail API
ii  libhsqldb-java                            1.8.0.10-6.1ubuntu1                               Java SQL database engine
ii  libicu4j-java                             4.0.1.1-1                                         Library for unicode support and internalisation
ii  libitext-java                             2.1.7-2                                           Java Library to create and manipulate PDF on the fly
ii  libitext-java-gcj                         2.1.7-2                                           Java Library to create and manipulate PDF on the fly
ii  libjaxp1.3-java                           1.3.04-5ubuntu3                                   Java XML parser and transformer APIs (DOM, SAX, JAXP, TrAX)
ii  libjline-java                             0.9.94-5                                          Java library for handling console input
ii  libjtidy-java                             7+svn20070309-4                                   a Java port of HTML Tidy, a HTML syntax checker and pretty printer
ii  liblucene2-java                           2.9.2+ds1-1                                       Full-text search engine library for Java(TM)
ii  libregexp-java                            1.5-2                                             Regular expression library for Java
ii  libreoffice-java-common                   1:3.3.2-1ubuntu2~maverick1                        office productivity suite -- arch-independent Java support files
ii  libservlet2.5-java                        6.0.28-2ubuntu1.2                                 Servlet 2.5 and JSP 2.1 Java API classes
ii  plasma-scriptengine-javascript            4:4.5.5-0ubuntu2                                  the JavaScript script engine for Plasma
ii  sun-java6-bin                             6.26-1maverick1                                   Sun Java(TM) Runtime Environment (JRE) 6 (architecture dependent files)
ii  sun-java6-jre                             6.26-1maverick1                                   Sun Java(TM) Runtime Environment (JRE) 6 (architecture independent files)
ii  sun-java6-plugin                          6.26-1maverick1                                   Java(TM) Plug-in, Java SE 6
ii  tzdata-java                               2011g-0ubuntu0.10.10                              time zone and daylight-saving time data for use by java runtimes
