cool Sweethome3d+Xinerama+4Screen+2GPU Setup?
This topic has been viewed 3467 times and has 1 replies
MaDDeePee
Post by MaDDeePee »
Hi guys,
im unable to start Sweethome 3D with Xinerama enabled.
Im running a Xinerama setup bound with 2 Nvidia Gfx and 4 Screens connected. (Geforce GT520 & GTX560ti)
Whenever i try to start Sweethome3d, this happens:
  • maddeepee@MaDWorkStatioN ~ $ /opt/SweetHome3D-3.2/SweetHome3D An irrecoverable stack overflow has occurred.
    # SIGSEGV (0xb) at pc=0x6d69d880, pid=1522, tid=1821494128
    # JRE version: 6.0_24-b07
    # Java VM: Java HotSpot(TM) Server VM (19.1-b02 mixed mode linux-x86 )
    # Problematic frame:
    # C [libnvidia-glcore.so.270.41.06+0xc8d880]
    # An error report file with more information is saved as:
    # /home/maddeepee/hs_err_pid1522.log
    # http://java.sun.com/webapps/bugreport/crash.jsp
    # The crash happened outside the Java Virtual Machine in native code.
    # See problematic frame for where to report the bug.
    # Abgebrochen maddeepee@MaDWorkStatioN ~ $
I'm already using newest Gfx drivers and also tested older ones, without success. DISABLING Xinerama make me able to use that program.
So....is this a xinerama or Nvidia related problem?
Does i have to post the logfiles or is my problem located with that output?
Yours :)
MaDDeePee
Re: Sweethome3d+Xinerama+4Screen+2GPU Setup?
Post by MaDDeePee »
OK, i found out that this is a Nvidia issue with their current driver revision...
