Hi.
I would like to have a "Full-HD"-Setting preset in the Create-Photo dialog.
Also, it would be nice, if the 3d-view window could be "set" or "force" to use the settings used in the mentioned dialog.
(it's quite hard to set the window to a size corresponding to a special size when "use 3dview proportions" is used in the create-photo dialog.)
macfrog
Full-HD Settings...
This topic has been viewed 6428 times and has 2 replies
Re: Full-HD Settings...
What do you mean by "Full-HD"? An additional quality level?I would like to have a "Full-HD"-Setting preset in the Create-Photo dialog.
I see what you mean but I'm not sure it's worth an additional button. Any other idea: I could append to the 3D view label of the Apply proportions combo box an information about the current proportion (4/3, 16/9...).Also, it would be nice, if the 3d-view window could be "set" or "force" to use the settings used in the mentioned dialog.
Full-HD would mean 1920x1080 resolution.
Aspect should be the same as 16/9.
greets
macfrog
greets
macfrog
