I just realised, i would like to have a button/context menu entry with the functionality of
select one object-> choose "Replace with obj...(but keep properties!)".
so, i have a box (place holder), with given dimensions, position and texture (the properties) and want to replace this box with, lets say, a table.
That's where my asked feature jumps in.
Could be useful for fast layouting, or changing wall cabinets without repositioning and so on.
What do you guys think?
macfrog
Feature "Replace with..."
This topic has been viewed 4580 times and has 5 replies
Re: Feature "Replace with..."
Well,
i see nobody really seems to understand/need the proposed feature, here's another example:
you created a scene with a nice looking lounge with a view looking out of the giant glass door to the garden. you want to setup the perfect spot to render and therefore you got to perfom a lot of test renders before you get it. now it happens your project contains many tree objects which slows down photo creation heavily.
so, with the feature i mentioned you only have to create some boxes with the dimensions of the real trees and your editing and spot-searching will be a lot faster until you finally can replace those boxes with any tree object in a second.
how about that?
I did mentioned the instant change of lets say, kitchen furniture, didn't i?
At least let me know about your doubts.
macfrog
how about that?
macfrog
Macfrog,
Like you, I would love to see a Replace feature. Maybe someone can program it as a plug-in? It would definitely save time when you want to do a what-if comparison, e.g. to see which of two different chairs would look nicer in a restaurant.
Sorry it's not possible to program such a feature in a plug-in with the current version.
In deed, if I remove a HomePieceOfFurniture from the Home, create a new one with the removed dimensions and coordinates (and maybe some other properties), and then add it to the Home (I can get the current Home from a Plugin, then get the selected items, remove and add) the rest would be a UI to choose from say, the catalog.
Emmanuel,
there is -of course- the already existant copy/paste functionality. what if you just have to select a new object and paste the object from the clipboard "onto" the selected object, but keeping the required properties from the selected (and soon to be replaced) object just to re-apply them after pasting?
could that be done? (from your pov?)
macfrog
macfrog
