Error when loading Sweet Home 3D Online on dual monitors
This topic has been viewed 3750 times and has 2 replies
crobusa
Post by crobusa »
java.lang.IllegalArgumentException: adding a container to a container on a different GraphicsDevice
Exception in thread "AWT-EventQueue-2" java.lang.IllegalArgumentException: adding a container to a container on a different GraphicsDevice
at java.awt.Component.checkGD(Unknown Source)
at java.awt.Container.checkGD(Unknown Source)
at java.awt.Container.addImpl(Unknown Source)
at javax.swing.JLayeredPane.addImpl(Unknown Source)
at java.awt.Container.add(Unknown Source)
at javax.swing.JRootPane.setContentPane(Unknown Source)
at javax.swing.JApplet.setContentPane(Unknown Source)
at com.eteks.sweethome3d.applet.AppletApplication$1.collectionChanged(Unknown Source)
at com.eteks.sweethome3d.model.CollectionChangeSupport.fireCollectionChanged(Unknown Source)
at com.eteks.sweethome3d.model.HomeApplication.addHome(Unknown Source)
at com.eteks.sweethome3d.applet.AppletApplication$2.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Thanks!
Charles
crobusa
Re: Error when loading Sweet Home 3D Online on dual monitors
Post by crobusa »
Sorry for replying to own post, but can't find the edit button :)
Java 1.6.0_21 under Vista, both IE7 and Firefox 4.
Google led me to think it's dual monitor
http://www.java.net/node/654619
Thanks,
It's not easy for me to fix this because I don't have any way to test it myself.
Please, could you report this issue in bug tracker to be sure I won't forget it?
