I would like to be able to have different wall shading or colour in plan view to show different types of wall construction ... is this possible?
Thanks
Ken
Can I change the shading or colour of a wall in plan view
This topic has been viewed 4754 times and has 5 replies
Re: Can I change the shading or colour of a wall in plan view
In plan view, you can just change the pattern of the walls with preferences dialog.
If you change the color of wall sides, you'll see the difference only in the 3D view.
Thanks but I don't want to change the shading of all walls, just some of them.
jorgesomers
I´d like to have a diferent pattern in plan which must represent 25 cm of wall.
Because I´m using a different type o brick which cannot be cut and all walls must be the size of multiple of 25 or 12,5 cm ..
If I had this "pattern" I can also visualy calculte other thing in the plan, like the place to fill with concrete etc..
If you need I can send you the icon I have the file in vector format.
jorgesomers, it has been possible to set a different pattern on each wall since the version 4.0 released in 2013!
jorgesomers
yes I know but I want my own pattern which will look like this brick
http://www.alroma.com.br/img/img-tijolo-02-g.jpg
and I want this kind of result using sweethome3d
http://www.alroma.com.br/pdf/exemplo_modulado03.pdf
