One click visibility setting
This topic has been viewed 3527 times and has 2 replies
Where I can see the furnitures' data in a table (width, length...) the visibility is a checkbox. Now to hide or show a furniture I must click twice on it and set visible checkbox and click ok button. My wish is one click in that table is turning on/off visibility. (or edit all datas in that table without open furniture's properties)
Re: One click visibility setting
daniferi,
yes, that's annoying, indeed. the entire furniture list is read-only, even there are checkboxes... styleguide is different from that on every OS, i believe...
Emmanuel???
macfrog
Emmanuel???
macfrog
My first idea was to make cells editable. But I felt that size columns would be often not large enough to be really usable. As I don't like that much the option where some columns like Visible would be editable while some others wouldn't, I finally chose to make all columns uneditable. What I should do at least, is using a non editable symbol for check boxes.
