Some time ago I found out that there are some transparant material names. WIthout using the D-option, these are transparant. I use them when building all kinds of structures. The nice part is that you can change the colour of the object, but the transparant material will not change colour. So you can make a window, and give it any colour you want, without the glass becoming the same colour, or losing its transparency.
I uploaded the files so you can download them if you like. Here are the direct links:
ftp://[email protected]/hansdi ... rtrans.obj
ftp://[email protected]/hansdi ... uetint.obj
ftp://[email protected]/hansdi ... merald.obj
ftp://[email protected]/hansdi ... _flesh.obj
ftp://[email protected]/hansdi ... _glass.obj
ftp://[email protected]/hansdi ... lutint.obj
ftp://[email protected]/hansdi ... sp_meh.obj
ftp://[email protected]/hansdi ... plasma.obj
ftp://[email protected]/hansdi ... p_ruby.obj
ftp://[email protected]/hansdi ... pphire.obj
Good luck!
[Note from moderator: splited Transparent (glass) furniture?? thread]
Re: Transparent (glass) furniture??
This topic has been viewed 5499 times and has 3 replies
Oh dear, oh dear, I'm so clumsy. Here are the correct links to the files.
I hope it works, if not, give a shout
- Attachments
- Box_transp_shadow.obj
- (937 Bytes) Downloaded 2421 times
- Box_transp_sapphire.obj
- (937 Bytes) Downloaded 2018 times
- Box_transp_ruby.obj
- (933 Bytes) Downloaded 1846 times
- Box_transp_plasma.obj
- (935 Bytes) Downloaded 2246 times
- Box_transp_meh.obj
- (932 Bytes) Downloaded 1908 times
- Box_transp_glassblutint.obj
- (941 Bytes) Downloaded 3288 times
- Box_transp_glass.obj
- (945 Bytes) Downloaded 14441 times
- Box_transp_flesh.obj
- (945 Bytes) Downloaded 2040 times
- Box_transp_emerald.obj
- (936 Bytes) Downloaded 2202 times
- Box_transp_bluetint.obj
- (937 Bytes) Downloaded 2980 times
- Box_transp_ambertrans.obj
- (940 Bytes) Downloaded 3639 times
- socrate_54
- Country: France
je sui novice en blender et j'essaye de créer une fenêtre en (.obj)
la forme est bonne mais seul le "ltbrown" est appliqué.
voici une extraction du fichier .obj
# Blender3D v249 OBJ File: GGL1.blend
# www.blender3d.org
mtllib GGL1.mtl
v 3.070711 2.010710 -2.150000
v 3.092388 1.978268 -2.150000
vn 0.831470 0.555570 0.000000
vn 0.831471 0.555569 0.000001
usemtl mintgrn
s off
f 33//1 1//1 2//1
f 34//2 18//2 17//2
v 3.499998 2.539997 -3.050000
v 3.500000 2.539995 -2.150000
v 3.499996 -6.460001 -2.150000
vn 1.000000 0.000000 -0.000002
vn 1.000000 -0.000000 0.000003
usemtl ltbrown
s off
f 89//35 92//35 88//35
v 3.099998 1.339998 -2.650000
v 3.099998 -6.059999 -2.650000
v -3.099999 -6.059998 -2.650000
vn 1.000000 0.000000 -0.000014
vn 1.000000 -0.000000 0.000021
usemtl glasstransparent
s off
f 97//47 93//47 96//47
Le résultat est le même si les divisions "v" sont précédées de g box1 g box1.1 g carreau
Avec un carreau seul cela fonctionne la transparence est bonne.
Testé sous windows XP et ubuntu 11.04 le résultat est le même.
sweet home 3D 3.3
blender 2.49
existe t il un utilisateur moins novice qui puisse m'aider?
Cordialement.
# www.blender3d.org
mtllib GGL1.mtl
usemtl mintgrn
s off
f 33//1 1//1 2//1
f 34//2 18//2 17//2
usemtl ltbrown
s off
s off
sweet home 3D 3.3
blender 2.49
Cordialement.
- socrate_54
- Country: France
j'ai trouvé pourquoi les transparences ne fonctionnaient pas.
dans le fichier .mtl était redéfini "newmtl glasstransparent"
en enlevant cette section voici le résultat.
Le mur est même découpé par cette fenêtre inclinée.
Merci aux développeurs de SH3D. Ce logiciel permet de visualiser avant de construire réellement.
Cordialement
Cordialement
