Hello
First a big thanks for this program, but I have a problem.
I need a kind of cut-out-tool to make holes in a wall with angle and without a frame.
I need this for my top floor flat, so is there anything I can use?
thx
Cut out
This topic has been viewed 16489 times and has 26 replies
Re: Cut out
Import the invisible box selecting the Door or window option during the 3rd step, and use one or more boxes of this kind to cut any wall or group of walls (it will cut only walls).
See also this discussion.
Re: Cut out
Hmm, I implement the invisible box, but after small test it doasn't solve my problem.
I will check the thread... thx
Re: Cut out
Mic,
Maybe this invisible hatch will solve your problem?
And eh, don't forget to check Door/Window while importing, or it won't insert itself in the wall.
- Attachments
- hatch invisible.zip
- (1.27 KiB) Downloaded 11571 times
Re: Cut out
Now it works basically.
check Door/Window while importing... was my mistake, thx for the hint
Problem is, I need an invisible wall/box or whatever which can make an angle on the top. Same system as normal wall have...sloping wall.
Is this possible?
Is this possible?
Re: Cut out
Mic,
Maybe you can apply a transparent texture to (a part of) the wall?
It will show up as black in the design, but will be invisible when you make a photo render.
- Attachments
- empty transparent.gif (1.95 KiB) Viewed 17558 times
Re: Cut out
Are you trying to do something like this????Problem is, I need an invisible wall/box or whatever which can make an angle on the top. Same system as normal wall have...sloping wall.
Is this possible?
Design created by Macfrog
Click to browse to the Original thread
if it is so then its quiet simple...? let me know if its the same thing you are trying to do or not??
Re: Cut out
Something like this.... The red area has to be removed.
Re: Cut out
Mic,
Share your design, or [url=mailto:[email protected]]send it[/url] to me. I don't understand exactly what you want.
