wall select problem
This topic has been viewed 3235 times and has 2 replies
geoff3
wall select problem
Post by geoff3 »
I have added a sloping piece of wall on top of an end wall to complete a house eve. I need to adjust its angle and to do that I need to select it. The problem is that the lower base wall is selected each time, how can I differential between the two?
Re: wall select problem
Geoffrey,
You can NOT stack walls. This gives unwanted side-effects.
1 - If you want to make a wall sloping, make it sloping.
2 - If you must have two different parts, make the sloping wall separately, use Tools --> Copy As New Furniture and then place it on top of the wall. Then, the wall isn't a wall anymore, but is converted to a normal furniture object, and those are stackable. This solution requires that you have the plug-in installed. (manual )
3 - If just the end-section of a longer wall should be sloping, select the wall, then do right-click --> Split walls. Adjust the length of the two sections, then make the end section sloping.
geoff3
Post by geoff3 »
Thanks Hans,
for a very clear reply, Split walls at the summit of the eve was the easiest
Geoff
